We put down vinyl plank flooring in our fiver. We replaced the carpet, because of a couple stains on our light colour carpet. The flooring we used came from HD, and each box has 3 plank widths. This gives it a more natural look, more like a hardwood. The colour we chose is very close to a reclaimed barn board. We found this colour to hide any joints as well as any potential mess. Whe we have friends over at our site we don't worry about anything that may get tracked in. The vinyl plank is floating floor so there are no glue joints to separate and show. Around the edges, I used the smalest cove molding that I could find to give it a finished look. The molding is pin-nailed to the cabinets and walls, not the flooring to allow for movement.of the floor. The flooring is very easy to install. I used a straight edge, a sharp utility knife to put down the floor itself in a single afternoon.
The vinyl plank is virtually waterproof in case of a spill. BIL has laminate in his camper and had a leak. The entire floor buckled and much of it may have to be replaced if the flooring does not return to its original position. It is also very easy to clean, a damp mop or broom is all thats needed to clean it.
