GaryS1953's avatar
May 21, 2018
Flooring Replacement
Hi All - due to a leaking fresh water drain valve I have to pull carpet and replace flooring. My wife has always hated the carpet so now is the time to put in what she wants. She'd like some sort of wood look flooring though out the kitchen dining living room area. Once all the carpet is removed, it seems all the flooring is one level, so it should be easy to also pull the linoleum material that's there. Previous owner had replaced the bathroom flooring with square stick-on vinyl tiles, and that has not worked out well at all. Any recommendations for wood-look type tile vinyl, and installation tips would be greatly appreciated.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
