Old-Biscuit
Jun 02, 2013Explorer III
Also even with a limited drain angle.....stuff flows down hill. So after dumping black tank fill it back up and dump again...repeat as necessary.
Having a clear adapter connected between end of dump line and sewer hose lets you 'see' how the stuff is flowing and when it's clean.
Then do a quickie flush of lines using the Flush King. As stated water flows under pressure just one way.....to the lesser pressured direction.
You are waiting until black tank is full/very full before dumping...right?
The 'stuff' in tank is carried out by the high volume/weight of the liquids. The higher the level before dumping the better the stuff gets evacuated.
Then after completely dumping/rinsing......add a few gallons of water back into tank so bottom of tank stays wet......less likely for stuff to stick to bottom, dry out, pile up and stink.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
