RayMc
May 12, 2014Explorer
rwbradley wrote:
Recent advances in password security have changed a lot of previous held assumptions. A few things to consider about passwords
1) any website that can tell you what your password is if you forgot it (instead of prompting you to reset it is using either a) no encryption b) reversible encryption, either way that means your data is stored using an insecure easily hackable method. The site should NEVER be able to tell you what your password is, this is an indication that they know your password.
2) a website forcing you to use a short password ie max 6 characters, or no special characters may be relying on old technology which may no longer be secure
3)password cracking tools are much more intelligent and most use a combination of 3 methods to crack a password a) dictionary attack which is checking known common passwords ie 12345 or password b) hybrid attack checks a dictionary than tries common number/letter substitution ie password1 or switching i for 1 o for 0 3 for e etc c) brute force attack, basically trying every possible combination. The first 2 methods take very little time to hack a password ie hours to days.
As the previous poster mentioned, complexity by using special characters, numbers and capital letters is important as long as it is not obvious complexity ie "pa33w0rd" is not significantly more secure than "password" using modern tools. Entrophy is key to a good password, do not think password, think passphrase ie MyBlueD0gHas3Tails is extremely secure. This comic makes the point:
http://xkcd.com/936/
Any site that forces you to use a short password should be assumed to be insecure, and I would contact customer service and complain... the squeaky wheel gets the oil (even in IT). Complex helps but bigger is better.
Just to clarify to previous posters, I'm referring to the "Pilot Good Sam Club RV Plus card".
In regard to the above, I did contact CS and was told that a third party company maintains the web site and accounts. According to the person I spoke with "Sir you have nothing to worry about, we have never had an problem". I understand and use long complex passwords.
I'm inquiring as to anyone here a. uses this service and b. finds a problem with Flying J's card account website.
Thanks,
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
