- Ray_INExplorer III
wanderingaimlessly wrote:
Horrible freight has put one on sale for Black Friday
Small comp
OK, now let the haters begin.
I have one I bought at Harbor Freight about 11 years ago. It served me well when we traveled in a 5er, but being an impatient guy I couldn't wait for it to add air to my 22.5" tires; so I bought a 150psi pancake compressor to carry in the MH.
I still use the 12V HF 150psi compressor for my other vehicles and farm equipment though. - CharlesinGAExplorerProject Farm on YouTube tested a smaller version of this compressor along with a whole bunch of others, and it came out 3rd of nine that were tested. He actually liked it alot.
Project Farm Youtube test of small compressors
Charles - CavemanCharlieExplorer III
Small comp
If you hate Harbor Freight so bad why do you bother with sales ad's?
How do you come to the conclusion the original poster "hates Harbor Freight"..:h
Probably because he called it "Horrible Freight" in his post. - DtankExplorer
Small comp
. - LantleyNomad
bucky wrote:
Lantley wrote:
The above dewalt inflator is a real game changer. Its self contained no need to plug in or connect to battery. I am able to inflate my 5th wheel tires wqithout being tied to an extension cord or battery.
It is able to inflate my 110 PSI Sailun G rated tires.
Yes more expensive than the El Cheapo models but it is also more capable. I own this model and can verify it works well.
DEWALT DCC020IB 20-Volt MAX Corded/Cordless Air Inflator can run on any 1 of 3 power sources for maximum versatility: 20-Volt maximum battery, 12-Volt DC or 110-Volt AC.
There is no cord attached,what you are seeing is an air hose.
I have a few Dewalt 20 volt batteries, A full 5 amp battery will top off all 4 of my 110 PSI tires.
However if a battery were to fail you simply put in another one just like any cordless tool.
How long does the battery last? I see cords attached, so much for no need to plug in. - JimK-NYExplorer III have a truck camper so I do not have a lot of space. I certainly don't want a big compressor that is likely to be used only once or twice a year.
So far I have gotten by with a small Slime brand compressor that looks similar but is smaller than the one shown from Harbor Freight. I forget the specs but it will pump a tire up over 100 psi....given enough time. If it finally dies, I can get a replacement at Walmart. So far after 10 years of use, the only issue is the inaccurate pressure gauge and the relatively low output.
My Slime unit is powered though the cigarette lighter and I don't need to worry about connecting to the battery or having enough wire to reach from the battery to the back tires. I have a 12v socket that is much closer to the rear tires. - buckyExplorer II
How long does the battery last? I see cords attached, so much for no need to plug in. - Bird_FreakExplorer II
Small comp
OK, now let the haters begin. - LatnerNomad
Esacnj wrote:
Looks like Viair
x2 I have the Viair version, looks the same - LwiddisNavigatorThanks for posting and the reviews.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 24, 2026
