- Grit_dogNavigator III
Esacnj wrote:
Looks like Viair
Yup. And the non sale price is actually fairly close to Viair price.
That one is slightly less cfm than the viair I bought this year for about $75. Seems comparable. Maybe even the same with a different label? Maybe a knockoff. - EsacnjExplorerLooks like Viair
- Sjm9911ExplorerI almost bought that one. But since thw new truck has a inverter and 110 outlet. I went with a small plug in 3 gal pancake compressor. Only good for 100 psi, but works well and fast.
- LantleyNomad
The above dewalt inflator is a real game changer. Its self contained no need to plug in or connect to battery. I am able to inflate my 5th wheel tires wqithout being tied to an extension cord or battery.
It is able to inflate my 110 PSI Sailun G rated tires.
Yes more expensive than the El Cheapo models but it is also more capable. I own this model and can verify it works well.
DEWALT DCC020IB 20-Volt MAX Corded/Cordless Air Inflator can run on any 1 of 3 power sources for maximum versatility: 20-Volt maximum battery, 12-Volt DC or 110-Volt AC. - buckyExplorer II
time2roll wrote:
Have had similar for 15+ years. Re-tapped the outlet to use a standard hose and chuck. As long as it has battery terminal clamps it is probably decent.
I see you figured it out also, the screw on attachment is a royal pain. A dually makes it even worse. - ROBERTSUNRUSExplorer:) Hi, I bought one of those Harbor Freight compressors many years ago. If you run it without being attached to a tire valve, it will blow up. Well at least mine did. I took it back as defective for a warrantee replacement and was hassled, but they finally gave me a new one. I installed a compressor blow off valve and never had a problem since.
- Have had similar for 15+ years. Re-tapped the outlet to use a standard hose and chuck. As long as it has battery terminal clamps it is probably decent.
- Boon_DockerExplorer III
Bobbo wrote:
I have one exactly like that with a different label. It is actually an excellent 12v air compressor.
X2
I have the same unit, different label. Used it many times and no complaints. - BobboExplorer IIII have one exactly like that with a different label. It is actually an excellent 12v air compressor.
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
