powderman426
Jun 03, 2013Explorer
It sounds like the tape they sold you was Eternabond. If so, that's as good as it gets for sealing leaks. It does require however that the surface be both clean and dry. Then when you put it down it needs to be rolled with some pressure on it to activate the sealant. Good luck to you
Looking for advice before your next adventure? Look no further.25,200 PostsLatest Activity: Jul 01, 2026
