Superpinky
Jun 03, 2013Explorer
kakampers wrote:
You want Dicor self leveling caulk for sealing the roof leaks...that is what is normally used during original construction to seal all openings and seams.
Thank you. I also have a rubber roof with fiberglass front and rear caps, And just as the guys at the repair place said its not meant for sealing those. They were spot on because it still leaks. Not as bad, but a leak is a leak. Might be a different story if your roof isn't rubber though.
I looked into using a tarp but im being told it will block all my vents and air conditioners air flow. Plus I don't have any good way to strap it down. Its a good idea in thought, but kinda a bust for MY situation fellas.
Looking for advice before your next adventure? Look no further.25,200 PostsLatest Activity: Jul 01, 2026
