Superpinky
Jun 21, 2013Explorer
I've been busy! We removed the gray tank altogether. We added PVC from point A to B so instead of going to a holding tank it just flows out. BUT, just in case this thing ever goes mobile again we added a T pipe that will force it to flow to the black tank for the time being. The only downfall is we would need to drain it twice as quickly. We tested everything and its working beautifully! The most cost was spent on buying two PVC parts that had valves to direct flow. Over all it was about 21$
Due to the tornadoes around here tarps are being giving out to whoever really needs one, so we got a big one and now it looks like we live in a circus tent. Were going to buy some of the self leveling calk next paycheck and will fix the bad areas. That will run me closer to 50. We also found its much MUCH cheaper to buy it online than in an RV repair or dealership.
The slide out is operated by a switch. Im guessing its hydrological because the front two legs to leveling everything are also hydrological.I could be wrong about that though. Two large bars are under it.
Thanks for all the replys by the way!
Looking for advice before your next adventure? Look no further.25,200 PostsLatest Activity: Jul 01, 2026
