rhagfo
Feb 02, 2020Explorer III
Dollarbill60 wrote:
rhagfo I am looking at a pin weight of 2575#. I found a label for an F350, had identical tire and rims as my 250, it just runs tire pressure to 80 psi instead of the 65 psi on my door label. The F350 label had a GVWR of 11500# and a rear GAWR of 6780#.I think with the bags and running 80 psi it should help significantly.
So you think you can run 18% pin on a 14,000# 5er and have a good towing experience with little or no chucking? My experience is I needed 22% pin to smooth out the ride.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 28, 2026
