Zigpep's avatar
Zigpep
Ford F-250 tow
Hello,
we have a fifth wheel with max weight of 14,300. We are no where near that but want to have a truck that tows over the 14,300. Fifth wheel is a 31.5 Nuwa. We have been searching for a truck for a while. Started out thinking we needed a 3500 duality but have seen so many Ford F-250 towing heavy fifth wheels we did a little more research and talked to a few people in campgrounds too.
From what we can see we should be good with a 2008 or newer Ford F-250 diesel super duty Single wheel (dually not necessary), with the tow package option ( from what I can tell it is standard on the 250).
My question is what are we missing? I’m sure there is something. I’ve checked the ford fleet tow ratings and we seem to be good. They have separate rating for conventional towing and fifth wheel towing on their websites. I really like the way they list the tow ratings, has been very difficult to find with dodge and Chevy. Initially our last choice was the ford. We know we don’t want anything older than the 2008 due to the issues with the 6.0 liter.
This option also puts us at our price point of about 25,000. Any one know of anything we have not considered re tow capabilities and also any glaring issues or problems with the 2008 to 2011 ford 250 diesel super duty?
Thanks zigpep
  • And stay away from the 2011-2012 6.7 unless you want to replace cracked heads.
  • I wouldn't personally buy a 6.0 or 6.4 Powerstroke. The 6.7 has been better but that limits you to (I think) 2011 or newer.
    As far as that era F250/350 goes, you aren't missing anything. They're either identical or identical aside from an overload spring and a different size axle block on the back. If the F250 you find is missing the overload spring, you can fix that by either adding one or installing bags/timbrens, and now you've got the same truck as an F350 (assuming tires are the same - check that too). Chassis, axle, brakes, etc. are all the same between the two. The difference in payload rating boils down to a heavy truck coupled with a class maximum GVWR on the 250, so it's an on-paper distinction. I'd tow that weight Fifth Wheel all day with a 250/2500 class truck as long as the tires were up to it.
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 05, 2026
