Monkei's avatar
Monkei
ford/Lincoln hybrid towing
I am planning on getting a new Winnebago Aspect. It has the Triton V10 engine and says the towing capacity is 5000 pounds. The Lincoln MKZ Hybrid is easily under that capacity by 400-600 pounds. We are planning on selling our BMW and my F150, one is way to heavy to tow and the Other can't be towed and is rear wheel drive so I can even use a tow dolly on it. I don't expect to scoot up mountains at 50 mph but since the Lincoln will be our only car we will be using it both as our everyday car and toad. Do you think I am chewing off a little too much for the V10? We sold the 425hp diesel last summer as we are downsizing.,
  • Yes, the Ford (and Lincoln) hybrids are easy to set up to tow. No fuses to pull or battery cables to disconnect. As Colo.newbie states, all you need to do is put the key in the ignition, turn it to ACC position, press on brake pedal to allow shift level to be moved out of PARK to NEUTRAL, then turn key back towards OFF (no battery drain in the near OFF position vs. ACC position).
    You can get a dummy key but I've always just used a regular key. (I've towed vehicles 4 wheels down for 20 years and never had an issue using a regular key.)
  • Monkei, it is very easy to hook my Fusion up, put the tow bar and safety cables etc. then go buy a dummy key for the car put that in the ignition and turn it to accessory position and shift into neutral then turn the back to off it will not go to off but stop short so the wheels will turn get out lock the doors and away you go
  • DouglasC wrote:
    I am towing a 2012 Ford Fusion Hybrid with a Class C motorhome with the Ford E450 chassis and V-10 engine. No problem whatsoever. You won't have a problem towing a Lincoln MKZ with a Winnebago Aspect. The MKZ is only a few lbs heavier than the Fusion. You'll love driving the hybrid, especially with the great fuel economy!
    Can you go thru the setup or steps that you take to prepare the fusion hybrid for tow. I am pretty sure the MKZ hybrid would take the same steps.
    Thanks again.
  • I am towing a 2012 Ford Fusion Hybrid with a Class C motorhome with the Ford E450 chassis and V-10 engine. No problem whatsoever. You won't have a problem towing a Lincoln MKZ with a Winnebago Aspect. The MKZ is only a few lbs heavier than the Fusion. You'll love driving the hybrid, especially with the great fuel economy!
  • I'm planning on towing a 2015 3.5L AWD MKS this fall.
    A few lbs. heaver then the MKZ.
    MKZ can only be pulled 4 down with the 3.7L engine or Hybrid model.
  • Hi,
    You can look up the towing guide, and see what vehicles can be towed 4 wheels down without a tow dolly. The 2014 MKS, MKX and MKT are listed, can not be put on a tow dolly with all wheel drive, but can be towed 4 wheels down with either AWD or FWD.
    http://www.fleet.ford.com/towing-guides/
    I think that if you have ever used a tow dolly and then went to 4 wheel down again, you will agree that 4 wheel down is the way to go. I had a Honda CRV with 4 wheel down towing, then started full timing with my Windstar van and tow dolly.
    Now I have a Edge, and love it much better, no need to find a place to put the dolly at camp, then back in the motorhome, then park the car, all while holding up traffic. Now I just stop, unhitch the car in a few seconds, unplug the wires, and then park it in a empty site, back the RV into it's space, and I move the car in front of me.
    The 2007 Edge can be towed 4 wheels down in either AWD or FWD. I have AWD, so can not use a tow dolly.
    I installed a diode kit in all of my towed vehicles. Yes even the van, so that the red tail light would turn on with my motorhome taillights. Then ran wire from the diodes to under the hood, and then to a connection to the motorhome.
    The V10 makes about 100 more HP than my 97 Bounder with a 460" V8 in it. You will have no problems going up the hills. You will also have either a 5 or 6 speed transmission, so can make it up the hills even easier. Due to the reduced weight, you probably can take hills faster than your DP could.
    The V10 has tiny pistons, moving a short distance with just 0.68 liters per cylinder. It can run 4,000 RPM for hours on end without a problem. Your DP might have had a 9 liter inline 6, with 1.5 liters per cylinder (think 2 liter soda bottle but slightly shorter). Turning that engine at over 2,700 RPM would be impossible due to the governor. It is the higher RPM's that give the V10 it's horsepower advantage. Run it at 4,000 and it will produce a lot of power. But get worse mileage. I would rather take it easy up the mountain pass, and save the fuel. I keep my motorhome around 45 MPH climbing to save fuel. You might find that your V10 works well at either 50 or 45, depending on the gear and engine RPM.
    Fred.
  • I talked with Lincoln about the upcoming MKC, and they could not yet say if it could be towed 4 wheels down?
  • I have a Ford Fusion hybrid so far no problems you will not fly up the hills but it will still get you there I have a 2008 Fleetwood with the v10
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 25, 2025
