ViaSteve2015
Feb 23, 2016Explorer II
If the UVW = 7321, then you will be 8K or more after loading gear, a little water, etc. IMHO, you don't want to tow more than 6,500 lbs or so with your truck. My Tundra is technically rated for 10K and I would never think of towing more than 7K. And, the payload factor is usually the limiting factor with a 1/2 ton truck.
If you want to play it safe, keep your tow weight to 75-80% of the maximum tow weight. Towing will be a more pleasant expereience and you won't find yourself in the position of owning a new trailer and discovering that you have to replace your tow vehicle, or sell the trailer. It happens all too often due to folks convincing themselves that their tow vehicle can tow the maximum weight (irregardless of payload).
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
