rhagfo
Feb 23, 2016Explorer III
The one thing that you didn't mention was the length which is 36' 5". I think your bigger issue will be the length, you will need a good setup and hitch.
based of the numbers below GVWR would be 9,571 lbs. so that is a lot of tail behind that F150.
GVWR TBD lbs.
Hitch Weight 771 lbs.
UVW 7,321 lbs.
CCC 2,250 lbs.
Exterior Length 36' 5"
Exterior Height 11' 5"
GVWR TBD lbs.
UVW 7,321 lbs.
CCC 2,250 lbs.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
