bmupton's avatar
bmupton
Fresh water tank bowed, broke propane lines
Another issue with my Crossroads Zinger ZT33BH.
Last Thursday, possibly the nicest day we've had all summer and definitely the best day of my summer vacation (that is sadly now over) the fresh water tank decided that it didn't need to stay in place.
It moved downwards, full of water, and put enough pressure on the propane lines secured to the frame to pull the self-tapping metal screws right out and break a brass fitting. I was filling the fresh tank at the time, and noticed a very strong propane smell so I quickly popped the cover off the tanks and shut them off.
After speaking to my dealer (Lardner's Trailer Sales in Saskatoon, SK, Canada), I packed it up and towed it to them late Thursday afternoon, and they had to order a new tank, but they fixed my old one enough and replaced the broken propane lines/fittings to get me through the rest of the season and I had my trailer back the next afternoon ready to go. Didn't even ruin the best weekend we've had all summer!
That being said, I'm now a little nervous to leave the propane on when we're sleeping and definitely nervous to leave it on when we're not there. It seems to me like running propane lines beneath tanks is a bad idea for this very reason. I just can't stop thinking, "What if this happened at 2am and it was somehow ignited while we were all snug in bed?"
I'm glad I noticed when I did and that it didnt' turn out worse, but there's a part of me that no longer feels safe and comfortable in my "new" trailer. My question is: what, if anything, do you think my dealer and/or the manufacturer should do to make my family feel safe in this trailer again?
  • I have now filed a complaint with Transport Canada, as I cannot file one with the DOT (their form requires a US address).
    I'm also in the process of writing a letter to Crossroads RV as well outlining my frustration with this trailer. It's not that any of my prior issues were that big of a deal to resolve, but when you add them all together you start to get the idea that their quality control and attention to detail are both lacking.
  • Snowman9000 wrote:
    Man, you'd think by now they'd know how to support a FW tank. The one on our 2004 Crossroads fiver was ridiculously poor. Many people had them fall out.
    After relaying this story around the campground (everyone had noticed I pulled out unexpectedly so they came asking when they saw the trailer back) more than one said the same thing...their tanks were poorly installed.
    relaxin wrote:
    mine the bottom sags a good inch or more in the middle ,but fortunately I don't have any other lines around it, I don't like the capacity of the tank so I am eith going to install a larger one or a second tank, wither way I will be customizing the brackets to better support the underbelly of it.
    my old TT had that issue with the black and grey tanks bowing about 1.5 inches lowere in the middle which then the solid would never completely drain out, so I build better brackets underneight.
    Those sound like issues that should have been covered under warranty. A tank that won't properly drain sounds like an issue the manufacturer should have to pay for, not you. Then again, if you want it done right, and right away, sometimes the only real option is to do it yourself.
    relaxin wrote:
    what is wrong with the engineers that design these things, I must be under some mistaken impression that they are smart
    You must be, because I've seen too much in this trailer alone to ever make that mistake. Though, my old '96 Mallard was awesome (though I did buy it twelve years in to its life, so all the kinks it may have had would have been long since worked out).
    Chris Bryant wrote:
    That is something that should require a recall- I would report it at https://www-odi.nhtsa.dot.gov/ivoq/.
    I really am speechless that a defect that bad- I mean you were not even driving when it happened, so no dynamic forces- would be present in a new model. I'm sorry, but every trailer of that model should be inspected and repaired.
    Is there a Canadian version where I can report this as well? (I'm in Canada). I whole-heartedly agree though. I didn't even haul the trailer with a full tank because I didn't want the extra ~500lbs of water weight right on my hitch (the tank is right up front). So it's never been tossed around full of water, it's only ever been sitting with water in it.
    EDIT: Here's what I found on the Government of Canada website: Clicky. Not sure if there's an online form available or not.
    EDIT 2: Here's an online form: Clicky.
    Alan_Hepburn wrote:
    That's a problem with all entry-level units: they do everything they can to cut costs. Move up a notch or two and you get tanks that are installed in the basement instead of slung under the frame - they get heat in the winter if you run your furnace, and they are more secure with a floor under them. But they are harder to work on because they are hidden out of sight!
    Cost cutting or not, there is NO reason this should happen. When people say "entry level trailers" I expect the quality of the fit and finish to be lower, not major problems with the quality of the actual construction and installation.
    There's no excuse other than pure human laziness and apathy.
    And, since this isn't the first FW tank installed this way to fall out of a trailer, the manufacturers know this method is prone to failure...you'd think they'd want to correct that problem in the design moving forward and save the money on warranty repairs.
    Oh, and I live in Saskatchewan...won't be using the travel trailer in the winter...something tells me that little furnace won't keep up with the -40 degrees. ;-)
  • That's a problem with all entry-level units: they do everything they can to cut costs. Move up a notch or two and you get tanks that are installed in the basement instead of slung under the frame - they get heat in the winter if you run your furnace, and they are more secure with a floor under them. But they are harder to work on because they are hidden out of sight!
  • That is something that should require a recall- I would report it at https://www-odi.nhtsa.dot.gov/ivoq/.
  • mine the bottom sags a good inch or more in the middle ,but fortunately I don't have any other lines around it, I don't like the capacity of the tank so I am eith going to install a larger one or a second tank, wither way I will be customizing the brackets to better support the underbelly of it.
  • Man, you'd think by now they'd know how to support a FW tank. The one on our 2004 Crossroads fiver was ridiculously poor. Many people had them fall out.
  • pianotuna wrote:
    Hi,
    So have the propane lines rerouted?
    As part of the permanent fix I think that is what I will tell them I want done. They need to take it all apart to install the new fresh tank anyhow, so I think that's an acceptable solution.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
