69_Avion
May 29, 2014Explorer
One of your check valves is leaking. (the one that is on the storage tank side of the system) If your RV is piped like the others that I have seen, that check valve is allowing the city water pressure to back feed into your potable water tank.
Most RVs will have two check valves. One to stop water from back feeding into the potable water tank and the other to stop the RV water pump from back feeding into the city water system.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
