Golden_HVAC
May 29, 2014Explorer
Old-Biscuit wrote:
Two ways water can get to fresh water tank while hooked up to city water
1) If you have valves/switches on a water panel the 'fill' valve could be leaking thru
2) Internal check valve of on-board pump is leaking back thru pump to tank
***If you have gravity fill forget #1. It's the pump check valve leaking.
You can disassemble pump and try to flush any debris, replace the internal check valve or install an in-line check valve in suction line to pump.
Sometimes just running pump will clear and debris holding check valve open.
Use it the rest of your trip and then test next trip/at home.
X2. Either the pump is leaking back into the tank or the fresh water filler has been left slightly open.
Fred.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
