TWZMYJP's avatar
TWZMYJP
Fresh Water Tank Question
We just purchased a brand new 2018 Carbon 387 toy hauler, and recently took it in for a bevvy of minor warranty issues. The only issue our servicing dealer could not address was the fact that we have to have ~30 gallons of fresh water in the tank for the water pump to function. The technician found the same issue and stated it is "as designed". Really??? Does anyone else have an RV fresh water system that requires you to maintain more than 25% of it's rated capacity in order to function? I mean heck, that means I get the pleasure of hauling around 30 gallons of water, and the 240lbs it weighs, without being able to access it?! Unfortunately Keystone is closed for the Thanksgiving weekend already so I sent them an e-mail, but wanted to get some feedback from the rest of the RV world? There is simply no way this can be "as designed"????
  • I had a similar issue. I ended up Teeing off the the freshwater tank drain and pump from there. I get every drop that way.
  • 4x4van's avatar
    4x4van
    Explorer III
    The pickup tube should "enter" the tank at/near the bottom. I've never seen one that entered higher and then extended down to the bottom.
    But even so, if yours is actually "as designed", then factory needs to "redesign" and fix it, period. No, it is not acceptable to have no access to 25% of your water.
  • Or there is a hole in the pickup tube so it sucks air when it isn't underwater.
  • The technicians "as designed" statement is one used 'as designed' to make you go away.
    Pump pickup tube is too short OR was too long and has curled backup.
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 26, 2025
