dedmiston
May 05, 2023Moderator
joebedford wrote:
Screw in connection is usually the black tank rinse.
Not necessarily. I've got three screw-in connections:
1. Black flush
2. City water connection
3. Fresh tank fill
Mine fills slowly too, but my blocker is in the vent and not in the fill. If I fill mine too quickly, it will puke out the vent line. My two problems are a narrow vent and a small line to equalize between my two 60 gallon fresh tanks.
My half-baked solution has been to put a valve on the end of my garden hose and then a meter after that and before the inlet on the coach. I zero out the meter, guestimate at how much water I need for the trip, set the fill rate low, set a timer on my watch, and then let it run while I do other things while I'm packing. It's very imperfect and I hate it, but it works for me.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 18, 2026
