SJ-Chris
May 05, 2023Explorer II
dedmiston wrote:joebedford wrote:
Screw in connection is usually the black tank rinse.
Not necessarily. I've got three screw-in connections:
1. Black flush
2. City water connection
3. Fresh tank fill
Mine fills slowly too, but my blocker is in the vent and not in the fill. If I fill mine too quickly, it will puke out the vent line. My two problems are a narrow vent and a small line to equalize between my two 60 gallon fresh tanks.
My half-baked solution has been to put a valve on the end of my garden hose and then a meter after that and before the inlet on the coach. I zero out the meter, guestimate at how much water I need for the trip, set the fill rate low, set a timer on my watch, and then let it run while I do other things while I'm packing. It's very imperfect and I hate it, but it works for me.
My RV has the same 3 screw in connections.
When filling the tank, at my home BEFORE going on a trip, it isn't a big deal that it fills slowly. Annoying, but manageable. My issue is when I'm out camping and I'm at a dump station that also has a hose for filling the fresh water tank. In that situation, it takes 30 minutes or longer which is unfair to anyone who might be behind me (...so I end up just filling as much as I can in a "reasonable" amount of time so as to not annoy people behind me).
Hopefully I can find a clogged vent/etc and fix the problem. Although I have a hard time imaging the vent getting clogged as the only thing that enters the fresh water tank is...water.
-Chris
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 18, 2026
