- fisher60ExplorerI use a 50' flat hose that comes on a reel. Works great.
- rk911Explorer
Chevyman2006 wrote:
Need some ideas on a NEAT way of storing my 50' fresh water hose. Would like something I could store it in, and remove the hose and storage "device" from compartment.
Thanks in advance.
i use a plastic hose reel similar to the one in the picture. mine has a handle on top, stores 100' of 3/8 hose and sits upright in the storage compartment..maybe 6"-8" of floor space. unreel as much as i need and reel it back in when done. couldn't be simpler. - ReneeGExplorerWe store ours in one of those clear storage containers with the top that meets in the middle and kind of overlaps. All fresh water stuff in one box, dump hoses and water hoses used for that in another, etc.
- Old-BiscuitExplorer III50' of hose is a lot of hose...especially when you try wrapping it up.
Might be able to coil it up inside a 5 gallon bucket....but don't know if that will fit thru compartment door of your rig.
Could cut it in half and install new ends (brass one...not those cheap plastic junk). Two 25' hoses are easier to coil up/stow. Plus usually only need one to hook up water. - Chevyman2006Explorer
PapPappy wrote:
I got one of those plastic Christmas wreath cases from Walmart. You can get a couple of hoses in it.....my problem, it's wider than my compartments are. I was tempted to stow it under the bed (lots of room, but a PITA to get at). I've yet to use it.
Prior to that, I had a Rubbermaid bin that fit in the compartment under the RV....it also allowed me a place to put some tools and fittings, as well as the water filter.
Yeah, that would take up too much room I'm afraid. I seem to remember something about a bucket, but can't find it.
I was also thinking about one of those circular wrap things for electrical cords, but not sure they make one big and sturdy enough for 50' of water hose. - PapPappyExplorerI got one of those plastic Christmas wreath cases from Walmart. You can get a couple of hoses in it.....my problem, it's wider than my compartments are. I was tempted to stow it under the bed (lots of room, but a PITA to get at). I've yet to use it.
Looking for advice before your next adventure? Look no further.25,161 PostsLatest Activity: Aug 30, 2025
