AK_Kid's avatar
AK_Kid
Fridge won't run on LP - any thoughts?
Hi, folks. I recently bought an '07 Winnebago Vista. It has a Norcold fridge that has just quit running on propane, and I could use some insight and suggestions, please.
We've been out on the road for a month. No issues running the fridge off of the LP until today. We stopped at a Wal-Mart early in the day, and I realized as we were loading groceries that the fridge had warmed up some. I checked the indicator lights. Both the green "on" light and the yellow "gas" light were flashing. Turned it off and back on a couple of times, to no avail. I could hear it trying to light - four or five clicks, then a pause, then clicks, then a pause. But the gas never ignited. I went outside and pulled the panel to get a closer look. As soon as I did that and the wife turned on the gas, presto - ignition. "Gremlins," I figured, and went back to loading the chow.
The fridge worked fine on gas most of the rest of the day while we were driving (about 350 miles). Then this evening we stopped an boondocked outside of a casino in New Mexico. Suddenly, both lights begin flashing again. This time I can't get the darn thing to restart. Tried pulling the panel, and I just cant tell what's going on (its dark and the wind is blowing 25-30 mph).
I can tell you that we're perfectly level and that we have plenty of propane. I've lit the burners on the stove and they work fine. But when I try to light the fridge, just clicking and no ignition. Should I try giving her a tune-up in the morning (check burner tube for rust/debris, check ignitor gap, clean propane jet, etc? Thoughts on what I should focus on?
Certainly appreciate any wisdom you folks might be able to impart.
  • Give a look and see where the igniter is and what condition it's in. The probe has to be in the flame to detect fire or it will quickly kill the LP (it's also a flame detect). That doesn't explain why no gas to start but it will certinaly explain why it shut off. This is a common failure.. I know... see the owners manual for exact placement unless someone here remembers
  • Can you get the pilot to light but then go's out? If so then its the thermocoupler. start here clean burner tube. Second will it run on AC?
  • My vote is also the burner tube....but, was it running, then shut down and wouldn't restart, or was it shut off for a period, then wouldn't start?
  • It could be air in the line, but if it was running for hours then that shouldn't be the case. Maybe rust in the burner tube and orifice broke loose. Check that and clean it out good.
  • On our previous MH, our Norcold would do the same thing when it had air in the line. We purged the air by getting the stove to light. It could take several tries to get it to light. Once it did, we would shut the fridge down and re attempt running it on propane.
    Ken
  • Cleaning the burner tube is where I'd start. If you pull the tube completely out then tap around on the stack above. Get as much loose rust out of it before reassembly. On previous MH our fridge wouldn't stay lit while driving but was ok when stopped. Did the cleanup I mentioned and worked perfectly after that.
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 24, 2025
