jkwilson
Nov 05, 2018Explorer III
Braces wrote:\
If you Google "Front Mount Hitch"you will see several hitches from several companies with easy bolt on installation for your truck.
There are several, but you either have to cut the air dam or have the hitch mounted so low it would cause clearance issues. The tow hook mount would seem to be the perfect solution.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
