mobeewan
Feb 03, 2019Explorer
I wanted a cooler rack for the front of an Isuzu Trooper I used to own. I took some measurements at the two points where the bumper mounted to the frame and had a shop cut 2 L brackets out of some 1/4 inch steel plate and drill the holes needed to use the existing bumper bolt locations using a sketch that I provided.
I purchased some 1-1/4 square tubing, 2 1-1/4 receiver sockets, 1/2 inch hitch pins and longer bolts to replace the original bumper mounting bolts. I already had some 2 x 2 angle and expanded sheet metal. I helped and a friend welded up everything for me. Later when I bought a small TT I had a spotting hitch made that I could pin into the 2 sockets to make moving the trailer around easier.
The only problem that I occasionally had was if I didn't pull or push the cooler rack or hitch evenly it would bind. I didn't want to use grease so I used a rubber mallet I kept behind the front seat to tap on it to get them sliding again.
What I did sounds like what you're thinking about with the hooks.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
