jkwilson's avatar
jkwilson
Explorer III
Nov 04, 2018
Front mount bike rack using tow hooks?
I’m in my shop trying to work out the simplest way to carry our bikes on the road with our 5th wheel.
Our rig doesn’t have a rear receiver, so installing one or beefing up the rear “bumper” are the options back there.
Short bed, and I can’t see any chance of carrying them in the back of the truck.
Looking into a front mounted receiver for a rack on the front. My concern is a low mount might cause ground clearance issues, and a high mount requires cutting the air dam.
While looking at the truck with tape measure in hand, it seems like the tow hooks are the perfect place to mount a rack. I could modify two 2” receivers to bolt on where the hooks go and then modify a a rack to mount to those. No permanent changes to the truck and no clearance issues. Seems so obvious I’m surprised google only gives vague references to such a product maybe having been available in the past.
Any thoughts?
  • I saw a mod at a campground a while back that kinda fits with your question.
    The owner replaced the front tow hooks with receivers, then modified a hitch with 2" stingers to fit. It was a super simple system needing nothing but a couple of receiver pins to attach. The hitch could easily be modified to include a bike rack or simply modify the bike rack itself.
  • I also looked at the receiver front mt at e-trailer. It looked solid, but yes, you have to cut out the air dam, which just looked cr@ppy to me. I don't know why no one has a ready made receiver to replace the tow hooks, but I think it is a great idea, if you are capable of fabricating your own design. Many 250s had the heavier springs up front (snow plow pkg, or HD service suspension), so the front axle may have lots of extra capacity, especially with the 6.2 gas.
    Jerry
