presh223
Oct 14, 2018Explorer
NRALIFR wrote:presh223 wrote:
Wow, so much good information, and you really went all out! What are you using for the base, did you fab your own or did you buy one and just put the box on top of it? You literally have thought of everything!
Thanks, it was a years-long project. Six to eight years at least. Use it, see a need, change it, use it, see a problem, change it........etc.
The base that’s holding the box to the truck is all custom made from angle-iron mostly. Some 2” square tube, and some flat plate where needed. The pintle hitch mount came from etrailer if I remember right. Speaking of which, that’s how I’d handle your front bumper hitch. There are pintle hitch mounts that can provide 12”-18” of drop. I’d buy one and build off of that rather than make any changes to your bumper. That thing is a beast!
If I ever need more approach angle clearance, I can raise the box up 6” by bolting it up higher on the pintle mount.
Now I'm thinking I may be forced to put my motorcycle in front and box in rear. The box will probably hold up better in the rear to any swinging action since I'll need an extension. The box will probably have 200lbs inside while the bike is 260lbs and has a higher center of gravity. I know people will just say get a trailer, but I want to keep the footprint as nimble as possible.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 07, 2026
