Sort By
- magnusfideExplorer III guess it's cheaper than buying a new roof unit. Sometimes aftermarket is way overpriced.
- JimBollmanExplorerSaw this a few weeks ago. Follow the 2X4 down and you will see the bottom is sitting on a cement block.
- robsouthExplorer IIIt's under the boat in the back of the truck. You can see the handle bars.
- JAXFLExplorer
magnusfide wrote:
robsouth wrote:
Glad I'm not following that rig. Incredible.
Where is the ATV? You have to have an ATV or Golf Cart. - magnusfideExplorer II
robsouth wrote:
Glad I'm not following that rig. Incredible. - Gene_GinnyExplorerWhen we checked in there was a sign in the office about giving Shopping Cart Rides for a donation to the local food bank :h ... I thought those things were a bit small for giving rides. Later when I saw this I understood.
- HandbasketExplorerIt wasn't in a CG, but parked in a yard near my doc's office. It actually had a valid TN plate on it at the time. I should note that there are several popular whitewater areas in WNC and east TN.
The hood is covered with a wood platform to ease getting to the overcab kayak rack. There appear to be wooden pull-out steps under the 'coach' door. The passenger's door window is plastic, with tasteful wooden trim.
Jim, "Why don't you bore a hole in yourself and let the sap run out?" - rv2goExplorer IIWatch out for that first step coming out.
- BudsterExplorer
Looking for advice before your next adventure? Look no further.25,130 PostsLatest Activity: May 04, 2025
