path1 wrote:
Jbrowland wrote:
With the simple digital ones you don't have to worry about if it is 12 volt or not correct?
Is not digital. See any digits on yours? Or just numbers pre-printed on plastic front?
Here is the description.
Exclusive heat only t-stat replaces both 12/24 volt or millivolt heating systems. fast and easy installation. large numbers for easy reading (and that's BS imo) Adapter plate included is used to replace round, vertical or horizontal t-stats. Unique adjustable thermometer allows matching of thermometer and temp setting. (that's the adjustment thing I was talking about earlier, so save your directions in case you have to fiddle with it later when you get into some cold climates later)
I meant if I do choose a digital one i stead of the basic unit.
