Jbrowland's avatar
Jbrowland
Furnace Won't Stop Blowing
Today I went to visit my RV in storage to get ready for Yosemite in a week. Last I left it three weeks ago, I disconnected the battery before I left. When I connected the battery the furnace started blowing and will not stop unless I disconnect the battery. First time this has ever happened. Any thoughts?
I did a search and found some possibilities but wanted more opinions. I thought it strange that it happened for the first time after I disconnected and then connected the battery for the first time (manually by hand) to leave the RV in storage. The battery is a sealed type 31AGM for RV's and is brand new.
The thermostat does not have an on or off switch but rather turns on when you raise the temp setting. It is blowing cold air and the thermostat is basically off as it is as low as it can go. Make sense?
2008 e350 Ford with a Majestic/Thor body. 24 foot class C.
Thanks!
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 05, 2026
