IHnutz's avatar
IHnutz
FW trailer level when towing
I'm sure this has been discussed before but?? How far off level is acceptable for the trailer to be when towing? With the trailer hitched to the truck on a level spot it sets about 2 1/2" to 3" high in the front. The truck is a 4x4 so it sets high from the factory. The pin box is raised as high as it will go. I am using a goose-neck adapter (no flaming about this, it is what I have) with ball mounted permanently to a plate under the 8' bed. The adapter is adjusted to it's lowest position. There is about 4" to 5" between the frame of the trailer and the bed so there is no more room to lower the front of the trailer.
Your opinions - is this a serious problem or just a fact of life I have to live with?
  • rhagfo's avatar
    rhagfo
    Explorer III
    That is a bit off, but you really need to know exactly how far off you are. If the front is 3" higher than the back, at the axles you may only need to raise 1.5" to 2".
    Best way to know exactly how much lift you need at the axles.
    First find a level space, and part TV and 5er connected.
    Then measure the distance from the top of the bed to the ground at the pin location, then add the desired 6" to that and call this Measurement1.
    Now, without moving the 5er, disconnect the TV and move forward for clearance, and level the 5er now measure from the ground to the bottom of the 5er at the pin location, call this Measurement2.
    Now time for the math, Measurement1-Measurement2 = the necessary lift needed at the axles for level tow.
  • mkirsch wrote:
    Yes, you need to raise the trailer.
    Even 2-3" off level is putting excessive weight on the back axle, which can cause problems down the road with excessive tire wear turning into blowouts.
    That's exactly what our snowmobile trailer mfr told us.. OP needs to raise rear of trailer. Min of 6" is best between top of box and underside of 5er.
  • Yes, you need to raise the trailer.
  • That's not enough bed rail clearance, and that's also pretty far off level. I had to axle flip my fifth wheel to get it to sit level - newer 4wd trucks are just really tall these days. Ram and Ford seem to be higher than the GMs. If your springs sit under your axle you can look into it. The new axle perches are only about $45 a pair from etrailer and it's a pretty easy job.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 15, 2025
