Lantley
Mar 07, 2016Nomad
smkettner wrote:lawnspecialties wrote:
What's the drawbacks of running these at 100 psi?
100 psi gives you 3550 rating.
http://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
Good Info smkettner.
My thought is why not get the full ability of the tire. I would not let the tire rating be determined by the valve stem.
If the tire can handle it but the valve stem can't get new stems.
For me the whole point of getting a better tire is to get increase margin.
If your towing a heavy trailer you want all the margin available.
If you have a 3750# rated tire but only need 3200# you have a 550# cushion. That cushion is what helps absorb the impact when you hit a large pot hole traveling down the road. That cushion is what gives you a safety factor on a super hot day as tires heat up.
The problem with ST tires is they have no additional margin or cushion built in. A passenger rated tires has 20% cushion built into the ratings. However a ST tire is not rated to carry passengers and does not have the cushion factor (safety margin) built into the ratings.
I want all the cushion/safety margin I can get. I don't want that cushion/safety/load rating to be compromised by something as trivial as a valve stem. I also don't want my tires to be limited by the valve stem.
TPMS is another reason to have metal stems.
In the end much in the same way a tire should at least match the axle capacity. The stems should also match the tire capacity.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
