TucsonJim
Mar 08, 2016Explorer II
smkettner wrote:
The rating is 100 psi cold. They are fine as temperatures rise during use.
You're failing to see the problem. If you set the tires for 100psi cold, they will increase to 115-120psi on a warm day while under tow. The valve stems are still only rated for 100psi. Therefore, they are seeing pressure in excess of what they are rated for.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
