fj12ryder
Mar 08, 2016Explorer III
Heck, you shouldn't have to remove the tire from the rim. All you have to do is break the bead in the valve stem area, hold the tire sidewall down out of the way, and install the valve stem. Should be able to do 6 tires in less than an hour easy.
I had the 6 tires off my toyhauler removed, the new tires mounted and balanced for a total of $75. Not done at a fancy tire store, but a fancy tire store isn't really needed.
Okay, I've rethought this, and if the $150 includes taking the tires off the trailer, and installing the new valve stems, and includes the cost of the new metal valve stems, then it's a little more reasonable.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
