lawnspecialties's avatar
Mar 08, 2016
G Rated Tires / Not Max Pressure
In another thread, we're discussing if the dealer gave me the proper valve stems for my G614s. They're certainly not the typical metal stems. The dealer is 260 miles away. So I'm fixing this thing here. I will be discussing this with them tomorrow for sure.
But if these are 100 psi rated stems, how much of an issue is it to just keep them and run 100 psi? I know I don't need the full 3750 lb. rated capacity at 110 psi. The camper originally came with E rated tires. I just wanted the G614s because the speed rating was 75 mph and I experienced a TowMax failure one trip and never want to go through that frustration again if possible.
What's the drawbacks of running these at 100 psi?
  • Probably nothing will happen for the tires but they will have more air pressure as you tow. I did not know the stems had a pressure rating.
    chevman
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
