Dmbaker07 wrote:
since I had 12v on both side of tsat I tested the board with a manual I found online.  it looks like the valve track portion of the board is bad.  all other tracks show continuity.
You found the problem.:) I used the online manual to check my board and  it showed it was broken. I ordered a dinosaur board from ASAP, 5 minute install, and it fired right up first time and worked much better then the OEM board ever since.
If you do order a dinosaur board, order the box with it. You need to be very careful when you attach it so the screws will not puncture the tank. Using the old screws and the box will/should eliminate that possibility.
