turner66
Aug 06, 2013Explorer
Maybe you've already considered this, and I don't know much about your specific brand of generator, but most portables have multiple outlets, with varying ratings, and seperate circuit breakers for each (or at least a breaker per group of outlets). It would be important to understand which circuit you're plugged into and the rating/protection on that particular circuit.
For example, I bet you have at least one 120v outlet rated and protected at 20A. If you were plugged into this one, I can easily see how you can have issues running more than the AC. In fact, my larger 15k AC draws right at 19A running on a 100 deg day.
You probably only have a single outlet which is capable of delivering the full output of the generator and that would be a 30A twistlock. If you're using this one and still tripping the gen breaker, I would get a clamp on amp meter and see what the draw really is when it trips. It could be tripping early, or you may have something that is just drawing more than it's normal rating.
Good luck
Good luck
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
