lacofdfireman's avatar
Oct 15, 2015
Everything works on Shore Power, Nothing on Generator
This morning before we left on a 4 day trip everything in our 07 Georgetown 350DS SE Class A Gas motorhome worked perfect. It's been fairly cool so haven't needed to run the generator or AC. But as we were going along it started to heat up so we went to turn on the Generator. Nothing. It won't turn on at all. You can hear a click when you turn the Thermostat to cool but it does nothing. Furnace works from same thermostat. Also none of the Tv's work or the Rear AC either.
So tonight when we pulled into the RV Park and hooked up to the 30amp Service everything works as normal. Weird. We have checked every fuse we could find and all the breakers and nothing is tripped or blown that we can see. Any ideas? I'm stumped. The Generator starts and runs but it does kinda make a sound like it's under a little load then it's not kinda off and on. Almost like it's starving for fuel or something but that's all I've noticed about that. But it will run nonstop for hours without issues...
Any help would be appreciated...
