RoyB
Aug 07, 2013Explorer III
It could also mean that the 30AMP connection is only 30AMPs when using 240 VAC. It may only be 15AMPs when using 120VAC. Need to read the book for the fine print maybe...
It may fall under the spec I listed above....
read what (4) says about using 120VAC/240VAC rated power available at the 30AMP connector if you are running 120VAC.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 12, 2026
