sato4000
Aug 12, 2013Explorer
UPDATE:
So I think i've figured out the issue now. I have to start the AC by first turning all the breakers off but AC. Then I can turn the fan on the ac on and then slowly turn the fan up to high. I can then turn the AC on with the cold set to medium and AC on medium. After all this I can slowly turn all the breakers on but the converter and fridge. At this point I tried turning the AC on high but it died. Started the same process over waited a long time then I was able to turn all the breakers on in the trailer. I'm not sure why I have to go through all this but it seems this is the only way to get everything on together. If I have AC on low and cold set to medium I can turn everything on right away.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 12, 2026
