eabc5454's avatar
eabc5454
Generator oil change/sythentic ?
Hello:
I have an Onan QG4000 generator that is due for its first oil change (20 hours). I have the owner's manual, and while it lists the correct oil based choices on temperature, it has no discussion on synthetic oil. I actually called Onan, and they said the owner's manual tells you what oil to use. Well, yes, it tells me viscosity, but not whether synthetics are OK.
So, here are my questions for those of you who are far more knowledgable than I:
Is it OK to use sythetic oil? If so, is there any benefit in doing so?
Thanks!
  • Newer Onans use splash lubrication, which is harder on oil than pressurized systems. I'd run dino oil for the first couple oil changes so the generator engine is broken in, then switch to synthetic.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
