georgelesley's avatar
georgelesley
Generator quits
We are in Iowa getting the toad modified for towing and some items fixed on the Winnebago motorhome. One thing that broke on the way to Iowa was the genny. Has always run fine but a few days ago it started as always ran less than one minute after the 110v was operating, and then quit and refused to start again. Turned over fine but no hint of starting. When it shut uff it was as if you had pushed the stop button, so I doubted it was fuel, but probably electrical.
Since we were at the Winne factory the next day we had then look at it. They said some wires had moved and interfered with the governor. They fixed that and they ran it for an hour w/o further problems.
The next day we drove to pick up the modified toad and planned to boondock there. Got there and started the genny. Ran again for a minute or so after the 110v clicked on. No load yet. Then it shuts off as before refusing all efforts to start it.
So, back to Winnie the next day. We boondocked in the parking lot. The next AM, I gave it a try and viola, it started right up. The Winnie tech then checked all wires, road tested for 10 miles, changed oil/filter and fuel filter, test ran for several hours, all ok.
The tech and I had a long conversation about what it might be. Oil low level sensor, circuit board, bad wire connector, loose ground, etc, etc. he claimed to have checked all of the above and found nothing. So we are staying the night here again and will be testing it several times. If the wind lays down we plan some driving on rough roads. If all is still ok, guess we will start home to TN tomorrow
Anybody have any other ideas we can check while we are here?
BTW, it is an Onan 5.5 HGJAB-1058 genny with a bit under 300 hours on it.
__________________
  • Problem solved. It was the fuel cutoff solenoid. The tech disabled the solenoid and all works well. I may or may not replace it at home.
  • 2003silverado wrote:
    How much fuel is in the tank? Generally generators in motor homes will shut off when the tank gets down to the half or quarter tank. Could be depending on how the vehicle is parked, sometimes it has enough fuel and other times it doesn't.
    We always keep at least 1/2 tank or more as we are aware of the genny needing 1/4 tank to run. The tech here this AM said he has seen many of these problems but this is the first time he has seen something besides low fuel being being the cause.
    Update. The tech and i agree we think it is the fuel shutoff solenoid. He has disconnected it and it has run perfectly for over an hour now.
  • How much fuel is in the tank? Generally generators in motor homes will shut off when the tank gets down to the half or quarter tank. Could be depending on how the vehicle is parked, sometimes it has enough fuel and other times it doesn't.
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 17, 2025
