nickthehunter
Nov 29, 2021Nomad III
If you are only looking to run 1 air conditioner, this is the one I have. Should be no problem running the micro and air conditioner at the same time. Obviously, if you need to run both air conditioners, you're going to need two. (You'll also need the adapter for 30 amp to feed 2 - 50 amp.) Clicky
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
