bikendan
Nov 30, 2021Explorer
bowler1 wrote:
I do like that Champion and people have said very good things about it. My only concern would be the noise level at 61db. That's a bit on the louder side of "quiet" generators.
I believe the Westinghouse and Cummins portable and similar variants are rated at 52DB. Because DB are a logarithmic scale the difference in 9DB should be fairly significant. Of course the way they are measured could be different (distance from generator and % load)
That is one other minor detail that makes me question if the Westinghouse and "Cummins" could truly be low quality. Generally the low quality and "cheap" generators are loud. 52DB is pretty impressively quiet.
I think I would pretty quickly jump on the Champion if it were quieter, but I might sacrifice volume for reliability.
Matt
Which Champion model are you referring to, that has a 61db noise rating?
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
