First - I am not what you might consider handy and so I generally pay to have things done. My MH has a 4KW Onan Microquiet gas genny. I purchased the MH from folks who rarely used it and found all...
Check the simple things first. Pull the spark plug wire off first an see it you have spark? Disconnect the fuel line to the carburetor and crank the eng are you get a steady stream of fuel out of the fuel pump? If you can answer these two questions your problem will be easier to diagnose.
Looking for advice before your next adventure? Look no further.25,209 PostsLatest Activity: Aug 28, 2026
