avan's avatar
avan
Genset issue
First - I am not what you might consider handy and so I generally pay to have things done.
My MH has a 4KW Onan Microquiet gas genny. I purchased the MH from folks who rarely used it and found all the systems they had to learn confusing. The generator would not start and I factored that into my offer. Preparing for last summer travels, I took the MH to a Cummins/Onan factory run RV facility in Ft Myers. They replaced the carb and had it running and returned to me in a half hour or so. I then traveled using the gen set frequently over the next 6 months. On my last night out, I used the genny for a couple of hours for AC and some TV and then turned it off before retiring for the night.
I finished my trip the next day and arriving at home early afternoon, I tried to start the generator. It would not start and that was only 8 hrs or so after having been started and run the night before. It hasn't started since. It will turn over and will run a few seconds if I use the starter spray.
So I'm a bit curious why a genset, with about 100 hrs on it, would suddenly not start in such a short period of time. I don't mind getting it fixed but would like to be a bit more educated on what might be wrong and how long a fix should last. Surely a fix should last more than 6 months at a time? What say you?
Looking for advice before your next adventure? Look no further.25,112 PostsLatest Activity: Feb 21, 2025
