ctann's avatar
ctann
Geometry question - can I make this turn?
Hi all,
Still yet to buy my new trailer, but I am trying to decide just what length I can go with. I have a tight turn across a bridge to get into my property, and I have seen people get stuck (or run up the curb and damage the bridge) trying to make the turn.
Of course, the one way to answer my question is to "try it out" - but I don't want to buy a 35' trailer and tow it to the bridge, only to get stuck!
So, the geometry is
- Making a left hand turn from a road onto a bridge
- Road is 34' wide, and I can get all the way over to the right before starting the turn
- bridge is 12' wide.
- My tow vehicle is an LWB F350 with a 28' turning radius.
I have made the turn with a 23' trailer with absolutely no problem. Now I am stepping up in trailer size - and I want to figure out just how long a trailer I can stretch to without getting stuck. I am hoping 30' will be OK, but I just *love* the layout of the 35' trailers, so I am getting greedy! :)
So I am going to go shopping, and hopefully they will let me "test-drive" - I'll set up some cones in a parking lot, and see if I can make the turn. Still, I would like some idea beforehand of what length I can go up to. Anyone have any advice?
Cheers,
Chris.
  • Can you overshoot your property and then back in? This would eliminate the choke point of the bridge.
    Is there a location farther down the road where can turn around? This would allow you to approach and depart the bridge without an immediate turn.
  • Hi,
    Maybe this will help. At our current place I have to do a 180 turn to turn the camper around in my yard. It's an ordeal but I figured out a way.
    We are building a new home and I did the drafting to layout the new pole barn, house and the barn yard specifically so I can turn around in my new barn yard and it be a non issue. And not go on the grass as spring time the mud in Ohio clay is really bad...
    So I did this. On my driveway at my current place, I backed the truck and camper 90 degrees from the drive onto my lawn. This created the skidding and end result of the turn. I did the max turn my F350 would do. Then got out and measured the camper and truck track path impression on the lawn. Then went to the drawing board. OK, the screen and mouse now a days.... This is what I have
    My F350, 4x4, crew cab short bed, and my 33.5' camper takes a circle center-line of 54' 8" driving the center-line of that circle to do a 180 degree turn.
    In the images you see above, it is 51' 2" from the top of the screen horizontal white parking lot edge line to the centerline path of the truck to do a 90 degree turn, not maxing the turn. Then I back up straight onto that camper turn around pad, do anther 90 deg turn and I'm heading back out of the yard the way I came in. Can back straight into the camper bay of the barn or drive right out driveway if wanted.
    This is the length of my rig. You can see how close you come to it
    A heads up, if you turn too sharp, be careful yo do not bust the WD hitch. Here at my current house, I take the WD bars off doing all that manipulating. At the new place, I made the turns large enough I leave everything all hooked up.
    I have a 2005 new front axle design for the 05's, 4 wheel drive and on the Fords, that 4 x 4 allows a tighter curb to curb turning radius then 2 x 4. 1.8 feet less according the Ford source book for my model year
    Hope this helps
    John
  • Chalk it out on a parking lot. Get a piece of rope equal to the distance from the ball to the axles and have an assistant hold onto the rope so it doesn't drag. Assistant should be carrying a board as long as the trailer is wide to see where the sides of the trailer will go.
  • Also you have to take the swing of the back of the trailer into the equation and whether there is room where it will be.
    X2 This is likely the biggest issue. You may have to get the trailer completely past the end of the bridge before making a serious turn.
  • Might take some practice but we turn tractor trailers with 53' trailers into a 12' fuel lane with about the same distance to make the turn. You just have to overshoot a little with the cab and bring it back. The tires on the trailer(RV) are closer and thus should turn better than our 53's at 41' from kingpin (MI legal). Just make sure you have room for the "butt" to swing.
    My semi tends to turn better than my F350 though.
  • Depends on the distance from the ball to the axles. Also you have to take the swing of the back of the trailer into the equation and whether there is room where it will be.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
