Mike_Up
Aug 14, 2012Explorer
CHD Dad wrote:
Be aware the new Blue Ox Sway Pro is not the same as the old style that everybody loves. I went through a mess with them and the dealer who sold it trying to get things sorted out. They completely changed the design without telling anyone about it.
The head is no longer tilt adjustable. It is cast at a preset tilt. If you want to put more or less pressure on the bars without using the chains, you are out of luck.
The sway control is no longer adjustable! They used to have two bolts at the bottom of the head to adjust the resistance to movement. Bolts are no longer there. Again, it is a preset adjustment and there was very little tension at all on the two I received.
They basically dumbed it down as much as possible. Nothing is adjustable other than how many links you pull on the chain. The only thing they kept was the rotating latch (very nice) and the pretty much grease free setup and use.
I ended up sending it back since I didnt like any of the changes and went with the Andersen system. So far I love it. Zero grease, no noise, no porpoising and quick hookup.
Yeh, I just called and now I don't think I'm going with this either. Everything you said is true so I asked whats the preset torque setting on the trunnion lobes. I told here I know they were adjustable up to 100 lbs and came from the factory at 40 lbs. She said they are free turning now, so I guess there's no friction sway control in the system anymore. The chain bracket provides some sway control but not much IMO as it's still allowed to shift around.
I'll just have to see what my options are. I might just go with a round bar system system since the cam was installed at the right spot for this and not a trunnion system.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
