F350R
Aug 14, 2012Explorer
I quit using my dual cam system after bending to of large friction cam knuckles during off camber turns. I went with the Reese SC WD system from Etrailer.com Its made similar to the Equalizer system but has friction pads under the WD bars for sway control. I haven't bent or broken any parts since changing to this system. Its easy to hook up, adjustment was easy and the friction control seems to be on par with the dual cam system. The SC system also doesn't hang but about two inches below the frame rails so ground clearance isn't a problem.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
