BarneyS
Aug 20, 2012Nomad
Mike Up wrote:
Found out some information on the NEW Blue Ox Sway Pro. I've been talking to their Engineer and Vice President and it may not be as bad as everyone is thinking. I may get this system
The rotating latches help with sway but are not the priority sway control in the hitch, the head is.
Snip...
As long as the WD bars pivot in the hitch head (and they all do) I can see no way at all that the chains, or whatever they are attached to, can help prevent sway. The bars, and attached chains, turn with the A frame when the trailer turns. They are NOT in a fixed position during a turn or sway event. They DO move forward and backward but this has nothing to do with sway control and the chains.
Yes, I know the Dual Cam system uses chains but they do not move at all. All they do is hold up the cams that the WD bars slide on.
How Blue Ox can claim that the rotating latches that wind up (tension) the chains contribute to sway control is beyond me. If someone can enlighten me as to how that would be possible I would be greatly appreciative.
Barney
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
