LITEPHIL
Aug 25, 2012Explorer
Housedad wrote:LITEPHIL wrote:Fisherguy wrote:
Mike, if the extra holes are that important to you they should weld up the old ones for you, grind them down and paint the A-Frame.
I still think the Reese is the way to go (with trunnion bars though)
Welding up the holes would more than likeley distort the frame in that area. I still think he should just get the Reese system dialed in. Its a really nice set up and really isn't that hard to set up.
Welding up holes on tubular trailer frames is done all the time.
If you take a piece of square tubing stock,drill a hole and weld it up,it will bow in the direction of the welded area. Better off leaving it alone or putting a bolt with a nut and a couple of flat washers in the holes. Fact
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
